Hello.
If Downstream is created using OOTB's BOM Transformer, Thumbnail is created in the Downstream Part, but if it is created in Java using the Windchill API, Thumbnail is not created.
Create a Downstream Part using the Windchill new BranchForView API.
When you create a Downstream Part, the thumbnail of the part created is not visible.
Upstream Part has Thumbnail.
I'm looking for a way to make the Downstream Part show Thumbnail.
A little bit of information is good, so please share it.
Thank you in advance.
Are you using something like below to create the EQL bnetween EBOM/MBOM :
EquivalenceLink link1 = EquivalenceLink.newEquivalenceLink(part,mPart);
link1.setIsConsumable(true);
link1.setUpstreamContextRef(part.getView());
link1.setDownstreamContextRef(mPart.getView());
link1 = (EquivalenceLink) PersistenceHelper.manager.save(link1);
That's right.
After creating Downstream with new BranchForView, we are doing equivalenceLink between objects with equivalenceLink.
I can't see the thumbnail even if I connect the equivalence Link
Can you enable below loggers to TRACE and share the logs as transformation is done from UI and API to compare .
com.ptc.windchill.associativity.copyover.CopyOverPropertiesParser
com.ptc.windchill.associativity.transform.copyover.ClassicTransformCopyOverDelegate
com.ptc.windchill.associativity.copyover.DefaultAttributesCopyOverDelegate
com.ptc.windchill.associativity.copyover.CopyOverData
