How to get WTPart from ESITarget
11025060
WTPart - > Related Objects -> Distribution Table,
if I right click on any row, the object type or the id is com.ptc.windchill.esi.tgt.ESITarget%3A299573938
I need to add custom logic to the 'Remove' button, depending on if the part is on any CA or not.
So, from com.ptc.windchill.esi.tgt.ESITarget%3A299573938
 is there a way to find out which WTPart it is related to?
indirectly, I am looking for a query/api to get WTPart from ESITarget
TDT
(To:11025060)
Hi @11025060,
What exactly is your requirement?
I don’t think that’s the right approach, there would be many objects associated with that DT.
Fadel
23-Emerald I
(To:11025060)
The link between DT and parts is com.ptc.windchill.esi.tgt.ESITargetAssignmentLink
Issue is that many parts may referring to the same DT, some  customer use one DT hence the one DT may reference all parts
we can define an alias attribute on DT type with mapping target@com.ptc.windchill.esi.tgt.ESITargetAssignmentLink~releasableObject^wt.part.WTPart
but it will show all parts
Fede
Imad_A
(To:11025060)
com.ptc.windchill.esi.tgt.ESITargetUtility.getTargetAssociations(Persistable object)
