How to get the Alternate usernames of WTUser using API
Navku
Is it possible to retrieve the value of Alternate user names of WTUser with API?
Navku
(To:Navku)
Using WRS Principal Domain, Retrieve the user's names and all details.
5 REPLIES 5
Cliff
(To:Navku)
https://www.ptc.com/en/support/article/CS137127
- Then no supported.
While if you just print a user, the attributes could include several UIDs, besides the one same as name, others are alternate names.
Cliff
Navku
(To:Cliff)
Hi ftian,
Thanks for the Reply,
Is there any use in providing alternate names for user?
Cliff
(To:Navku)
No really usage, just an alias of user's login name - user will have two logins and anyone can be used to login Windchill, while with same WTUser/ User Name.
- if look LDAP, you will find two UID attributes for the DN
Cliff
Navku
(To:Navku)
smartel
(To:Navku)
Just in case someone else is searching for that here is how to do it using java API
wt.fc.ObjectIdentifier oid = wt.fc.ObjectIdentifier.newObjectIdentifier("wt.org.WTUser:123");
wt.org.WTUser theUser = (wt.org.WTUser) wt.fc.PersistenceHelper.manager.refresh(oid);
String alternateName = wt.org.OrganizationServicesHelper.getAlternateName(theUser, WTUser.ALT_USER_NAME_1);
