Hello, please tell me how to open the entire Windchill project in Intellij Idea to edit and compile files?
As a basis on should use CS348994
ant -f create-eclipse-libs.xml
to create libraries to be used for eclipse development with java 11 and windchill 12.0.x
After this you can easily create a intellij project with these libraries
