I haven't tried, but I think I could do it this way:
Starting with an EPMDoc, get the representation:
VisualizationHelper vzh = VisualizationHelper.newVisualizationHelper();
QueryResult rep = vzh.getRepresentations((Persistable) epmDoc);
Then get content files in the rep:
ContentHolder holder=ContentHelper.service.getContents(rep);
Vector contents=ContentHelper.getContentListAll(holder);
Iterate through the vector: data=(ApplicationData)contents.get(i);
and check each filename (data.getFileName()) for the .ast extension which seems to be an annotation set.
Seems like there should be some simpler method. Anyone know a better way?
I did some testing with the method I described above. I can get a list of the filenames in the rep, but it does not include annotation files. In the UI, when I save the rep I have the option of including annotations:
And I can save an annotation like I can save the rep:
But, I don't know how to use the VisualizationHelper and ContentHelper to do it.
Figured it out. Used ViewMarkUpHelper.service:
boolean block;
block = false;
QueryResult qr = ViewMarkUpHelper.service.getMarkUps((Viewable)myrep);
while (qr.hasMoreElements()) {
Object object = qr.nextElement();
if (!(object instanceof WTMarkUp) || ((WTMarkUp)object).getMarkUpType() == MarkUpType.LANDMARK) continue;
block = true;
break;
