Version: Windchill 12.1
Use Case: Real time updation of wizard steps.
Description:
Hi, I have a custom promotion request wizard in which on the 1st step i am collecting some attribute values and then using them on the 4th step to propagate the step, but if i go back to step 1 and update some attributes, the values are not reflected on the 4th step immediately. Is there a way just to reload that specific 4th wizard step.
Did this article not help? Not sure if you tried it:
https://www.ptc.com/en/support/article/CS253380?source=search
Its an example so you might have to tailor to your example but you are basically having it call a javascript function defined in beforeJS that does the reload. If you need specific help, would you mind sharing your setup and screen shots of wizard? Redact anything you need to.
I have tried this solution, but on my 4th wizard its not only a table or tree builder but html tags also that needs to be re-calculated. So, this doesn't really helps me to reload the whole step.
I like learning from examples. One that might be a good source is document creation where it asks for a soft-type to be select on one screen and then presents a UI to match on the second. If you go back and change the first screen, the second must be reloaded I would assume. I would go hunting for existing examples and how they did it.
