How to retrieve Primary End Item via REST API — full endpoint example?
GS_12696423
Version: Windchill 13.0
Hi everyone, I found a reference in the ptc support explaining that it’s possible to retrieve Primary End Items in Windchill using REST API by filtering on WCTYPE|wt.pdmlink.PDMLinkProduct as typeId and selecting productReference. However, I’m not sure what the exact endpoint is to call in order to retrieve this data.
Link: https://www.ptc.com/en/support/article/CS271349
Could someone please share a concrete example of the full REST endpoint (including base path and entity name), ideally with $select or $expand usage if applicable? Thanks in advance for your help!
Description:
Retrieve Primary End Item via REST API
2 REPLIES 2
GS_12696423
(To:GS_12696423)
Just to clarify - I'm specifically looking to retrieve this data using the OData API, not WRS or classic REST. Appreciate any examples or guidance.
AndrewK
Community Manager
(To:GS_12696423)
Thank you for your question.
