How to return described by documents on an attribute using data utility
bhagavar
Version: Windchill 13.0
Use Case: Hi there, I want to return described by documents to the layout. So far i'm returning wt document. I need help in constructing URL and return, kindly help, thank you
Description:
Return link to layout using data utility
Hi @bhagavar,
Thank you for reaching out with your question.
To assist you better, could you please provide more details and context regarding your inquiry?
You could add things like:
  1. What specific challenges are you facing when constructing the URL?
  2. Do you need the described-by documents to be filtered based on certain criteria?
  3. What format should the returned link be in?
  4. Are there any existing solutions you've tried that didn’t work?
  5. Are you looking for a dynamic or static URL return?
Including screenshots can also be very helpful in understanding your process. This will enhance the likelihood of receiving valuable assistance from other Community members.
You might also find it useful to refer to the guide on how to ask a good question. Additionally, our community champion has shared a tip on key points to include when asking a question on the PTC Community.
I hope this information is helpful.
Best Regards,
Vivek N
Community Moderation Team.
