Version: Windchill 12.0
Use Case: Need to create a drawing file list in Windchill active workspace
Description:
I am working on a vb.net app. Part of its function is to export all drawings under active workspace to PDF format with a custom stamp. However, I cannot get the creating file list work as it is very confusing how to extract the file list from workspace. Can anyone provide a piece of sample VB code or this purpose?
Hi @SC_TK
I am sure you are talking about a Creo Toolkit, because the VB is not used in the Windchill.
So you should ask the Creo toolkit experts.
PetrH
Hi @SC_TK
PetrH
