How we can copy the windchill dynamic url through java code?
CH_10067600
How we can achieve the to copy the windchill dynamic url through java code? from part action menu with (new action item).
3 REPLIES 3
Hello @CH_10067600
You need to describe what you are trying achieve.
There are apis to generate URL to a object.
Here is example how to get URL to persistable object detail page
(persistable object can be any object in the system , WTPart, CADDocument, WTDocument)
NmOid workOid = new NmOid();
workOid.setRef(persistObject); // persistObject is a object as a WTPart and so on. You just need to search for them with another API....
NmAction workNmAction = NmActionServiceHelper.service.getAction("object", "view");
workNmAction.setContextObject(workOid);
String objURL = workNmAction.getActionUrlExternal();
Hope this can help
PetrH
Can it be done through javascripts ?
Could you please the steps ?
Hi @CH_10067600
I couldn't I do not know the PTC javascript library so deeply and I do not use them so often.
I call the java method directly on the jsp page
PetrH
