I want to set revision schema like 1D.0 , 1D.1 , 1D.2 , 2D.0 , 2D.1 , 2D.2 ... in default "wt.series.HarvardSeries"
Can anyone tell what necessary changes I need to do in wt.properties (or somewhere else) so i can achieve versioning in above format.
Please Help.
KU
Hello @KU_10670946
You need to add own versioning schema to StateBasedVersioning by XML load and set the OIR rule for the object where you need to set the versioning schema.
here is an article that describes how to change the series CS148182
PetrH
Hello @KU_10670946
PetrH
