java.util.NoSuchException alert is showing Please let me if any solution is there.
Can you post your OIR for WTPart in this area? I think its having an issue processing some of those rules.
Have you checked the Methodserver log for detailed error message? if yes please share the error message.
Also is this error with OOTB or customized Windchill instance?
Thanks for the reply @Devidas(Devi) Yes its with OOTB or customized Windchill instance
Method server -
ERROR : com.ptc.jca.mvc.controllers.ActionController wcadmin - java.lang.reflect.InvocationTargetException java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at com.ptc.netmarkets.util.beans.NmCommandBean.execute(NmCommandBean.java:2247)
at com.ptc.jca.mvc.controllers.ActionController.executeWizardAction(ActionController.java:222)
at com.ptc.jca.mvc.controllers.ActionController.processRequest(ActionController.java:125)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:190)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:138)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:105)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:878)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:792)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1040)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:943)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:909)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:652)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:733)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at wt.licenseusage.licensing.LicenseFilter.doFilter(LicenseFilter.java:47)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at com.ptc.core.ui.validation.URLValidationFilter.doFilter(URLValidationFilter.java:86)
at wt.httpgw.filter.WTContextBeanFilter.doWithWtContextBeanHandler(WTContextBeanFilter.java:104)
at wt.httpgw.filter.WTContextBeanFilter.doFilter(WTContextBeanFilter.java:58)
at wt.servlet.CompressionFilter.doFilter(CompressionFilter.java:301)
at wt.servlet.RequestInterrupter.doFilter(RequestInterrupter.java:335)
at wt.servlet.ServletRequestMonitor.doFilter(ServletRequestMonitor.java:1677)
at wt.servlet.ServletRequestMonitorFilter.doFilter(ServletRequestMonitorFilter.java:57)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:544)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:143)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:364)
at org.apache.coyote.ajp.AjpProcessor.service(AjpProcessor.java:526)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:831)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1639)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: wt.rule.RuleException: java.util.NoSuchElementException
Nested exception is: java.util.NoSuchElementException
at com.ptc.core.rule.server.delegate.init.TypeBasedInitRuleApplier.applyRule(TypeBasedInitRuleApplier.java:348)
at com.ptc.core.rule.server.delegate.init.TypeBasedInitRuleApplier.applyRule(TypeBasedInitRuleApplier.java:212)
at wt.rule.impl.StandardRuleService.applyRule(StandardRuleService.java:382)
at wt.rule.impl.StandardRuleService$1.notifyVetoableMultiObjectEvent(StandardRuleService.java:985)
at wt.events.StandardKeyedEventBranch.intDispatchEvent(StandardKeyedEventBranch.java:306)
at wt.events.StandardKeyedEventBranch.dispatchVetoableEvent(StandardKeyedEventBranch.java:255)
at wt.events.StandardKeyedEventDispatcher.intDispatchEvent(StandardKeyedEventDispatcher.java:304)
at wt.events.StandardKeyedEventDispatcher.dispatchVetoableEvent(StandardKeyedEventDispatcher.java:228)
at wt.services.StandardManagerService.intDispatchVetoableEvent(StandardManagerService.java:410)
at wt.services.StandardManagerService.dispatchVetoableEvent(StandardManagerService.java:303)
at wt.fc.StandardPersistenceManager.dispatchVetoableEvent(StandardPersistenceManager.java:2972)
at wt.fc.StandardPersistenceManager.dispatchVetoableEvent(StandardPersistenceManager.java:2952)
at wt.fc.StandardPersistenceManager.store(StandardPersistenceManager.java:1429)
at wt.fc.StandardPersistenceManager.store(StandardPersistenceManager.java:534)
at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:399)
at com.sun.proxy.$Proxy28.store(Unknown Source)
at com.ptc.core.components.forms.CreateObjectFormProcessor.doOperation(CreateObjectFormProcessor.java:98)
at com.ptc.windchill.enterprise.part.forms.CreatePartFormProcessor.doOperation(CreatePartFormProcessor.java:280)
at com.ptc.windchill.enterprise.part.forms.CreatePartAndCADDocFormProcessor.doOperation(CreatePartAndCADDocFormProcessor.java:120)
at com.ptc.core.components.forms.DefaultFormProcessorController.executeDoOperation(DefaultFormProcessorController.java:538)
at com.ptc.core.components.forms.DefaultFormProcessorController.performExecuteDoOperationAndPostProcess(DefaultFormProcessorController.java:342)
at com.ptc.core.components.forms.DefaultFormProcessorController.execute(DefaultFormProcessorController.java:263)
at com.ptc.core.components.forms.FormDispatcher.callControllerExecute(FormDispatcher.java:146)
at com.ptc.core.components.forms.FormDispatcher.callFormProcessorController(FormDispatcher.java:116)
at com.ptc.core.components.forms.FormDispatcher.execute(FormDispatcher.java:93)
... 62 more
Caused by: java.util.NoSuchElementException
at java.base/java.util.StringTokenizer.nextToken(StringTokenizer.java:349)
at wt.enterprise.EnterpriseHelper.getNumber(EnterpriseHelper.java:196)
at com.ptc.windchill.enterprise.revisionControlled.server.impl.NumberGenerator.calculate(NumberGenerator.java:44)
at wt.rule.algorithm.RuleAlgorithmHelper.calculate(RuleAlgorithmHelper.java:116)
at wt.rule.algorithm.RuleAlgorithmHelper.calculate(RuleAlgorithmHelper.java:74)
at com.ptc.core.rule.server.delegate.init.Utils.getValue(Utils.java:1160)
at com.ptc.core.rule.server.delegate.init.Utils.applyTo(Utils.java:693)
at com.ptc.core.rule.server.delegate.init.Utils.applyToWithNoLogging(Utils.java:465)
at com.ptc.core.rule.server.delegate.init.Utils.applyTo(Utils.java:285)
at com.ptc.core.rule.server.delegate.init.Utils.applyTo(Utils.java:497)
at com.ptc.core.rule.server.delegate.init.TypeBasedInitRuleApplier.applyRule(TypeBasedInitRuleApplier.java:332)
... 90 more
Hey thanks @avillanueva you said about OIR.
I was wrong in OIR that's why it was occurred.
im getting the same error, what you did on the OIR to resolve the Issue?
He never posting the OIR but was able to find the error? Do you want to post yours?
