Version: Windchill 12.0
Use Case: Automating BOM imports from an external process
Description:
I have a tool that exports out an Excel BOM to be imported into Windchill. Has anyone worked on a method for "import from spreadsheet" that is started from an outside process? For instance my tool could run some script that would automate the import from spreadsheet workflow in Windchill for a given Excel file path.
Has anyone worked on a script that does the import automation?
If it helps, we use single sign on so the user would not have to authenticate with Windchill.
Hi @Chris3
What do you want to automate?
Grab the excel file, read it and import the bom to Windchill without a user's interaction?
If yes, then you have two options.
1. Create a customization in Windchill to automate this process based on some event. For example workflow or schedule queue.
Or
2. You can use RestAPI and write an own application that uses the RestAPI's functions to create a BOM based on your input...
If you want to just use the Excel as a input for a user then
you have three options
1. Format the excel to the OOTB importable spread sheet and use it for import... you use only OOTB import function in Windchill
2. Write own custom function that read the excel and create BOM as you need by standard Windchill APIs.
3. Use extension Excel Loader that can import parts and BOMs
PetrH
Hi @Chris3
Or
PetrH
My Excel file is already in the OOTB importable spreadsheet format. I just want to eliminate the user from needing to go to Actions -> Import from Spreadsheet. It needs to start once my tool is finished writing out the Excel file. Sounds like my tool needs to call the RestAPI. I will look into it.
Hi @Chris3
Then you can use RestAPI but you have to understand how to use it, but it also applies to java coding 😄
or you can create own function that you call by http request and you upload the file to the server and process it by java code in the Windchill.
PetrH
Hi @HelesicPetr
I'm trying to use the same OOTB Import from Spreadsheet functionality to create link between parts. For that, where can I get the sample OOTB importable spread sheet template? And also how I can I link my custom function to the Import from Spreadsheet functionality? Like can I overrirde the Validate Spreadsheet and Import methods in the wizard?
