Dear Users,
I am trying to write a EPMSuggestBox which will shown all EPMDocument when the Global Atribute DOCUMENT_TYPE= 'SAAF' . I've tried the below search using where clause , but still the text box shows other EPM Documents where DOCUMENT_TYPE<> 'SAAF' .
Can you please share your ideas.
Regards
Sriram Rammohan
protected void setTaskParams(Task paramTask) throws WTException,
IOException {
WTUser localWTUser = (WTUser) SessionHelper.getPrincipal();
WTProperties localWTProperties = WTProperties.getLocalProperties();
String str = localWTProperties.getProperty("wt.federation.ie.VMName");
paramTask.setUsername(localWTUser.getAuthenticationName());
paramTask.addParam("object_type", "wt.epm.EPMDocument|com.xxx.DefaultEPMDocument");
paramTask.addParam("search_type", "wt.epm.EPMDocument|com.xxx.DefaultEPMDocument");
paramTask.addParam("where", "(name='" + this.search_term.trim()
+ "')&(checkoutInfo.state!='wrk')&(latestIteration='1')");
/*paramTask.addParam("where", "(DOCUMENT_TYPE='SAAF')");
paramTask.addParam("where", "('IBA|DOCUMENT_TYPE'='SAAF')");
paramTask.addParam("where", "IBA|DOCUMENT_TYPE=SAAF");
paramTask.addParam("where", "IBA|DOCUMENT_TYPE='SAAF'");
paramTask.addParam("where", "(IBA|DOCUMENT_TYPE='SAAF')");
paramTask.addParam("dca_attribute", "name");
paramTask.addParam("dca_attribute", "number");
paramTask.addParam("dca_attribute", "type");
if (this.excludeSubTypes != null)
paramTask.addParam("excludeSubTypes", this.excludeSubTypes);
paramTask.addParam("group_out", "output");
paramTask.addProcessor(str);
paramTask.addParam("supporting-adapter", str);
