Info*Engine remove duplicates in a group
rkassmeyer
I just thought I would drop a note here, since I was not able to find anything useful myself when looking for a solution around this: "I have a group with duplicates how do I remove them, it is adversely effecting a join?"
I have come up with this solution that seems to be straightforward, use it if you like it.
EXAMPLE:
<?xml version="1.0" standalone="yes"?>
<%@page language="java" access="http"%>
<%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"%>
<ie:webject name="Create-Group" type="GRP" >
      <ie:param name="DELIMITER" data="," />
      <ie:param name="ELEMENT" data="obid=A,color=red" />
      <ie:param name="ELEMENT" data="obid=B,color=blue" />
      <ie:param name="GROUP_OUT" data="DUPLICATES" />
</ie:webject>
      <ie:param name="GROUP_OUT" data="UNIQUE" />
</ie:webject>
<ie:forEach groupIn="DUPLICATES" groupOut="ROW" >
      <ie:webject name="Union-Groups" type="GRP" >
            <ie:param name="GROUP_IN" data="UNIQUE" />
            <ie:param name="GROUP_IN" data="ROW" />
            <ie:param name="UNIONBY" data="obid" />
      </ie:webject>
</ie:forEach>
NOTE: This only compares the data on the attribute "obid", no other values are considered.
I am not looking for a solution, I am posting this as an informative post.
What I have posted is a solution using Info*Engine.
fivig_flex
(To:rkassmeyer)
Looks like you have to use Java
Group group=null;// get by name
 group.removeElement();// dublicate condition
