Issue in custom javascript method
AS_10366434
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.2
Hello team, we are trying to propagate the custom.jsfrag file content using the below command-
ant -f jsfrag_combine.xml
but this command doesnt work. The issue we are getting is on one of our custom actions that have a corresponding javascript method attached to it.
Kindly provide us with a resolution for the same.
Without any errors, logs, and a description of what you customized, it won't be possible to answer your question.
Wow, you’re really not going to tell anyone what the error is nor post your code so that we can find and point out the problem.
