Version: Windchill 12.0
Use Case: Deployment Automation
Description:
Hi all,
As a part of deployment automation I wanted to know if there is any way to Export and Import Type Constraints especially Legal Value Lists easily. Like maybe a Loader file.
Hi @MV_10441462
You can automate the import of the softtype configuration by OOTB function loadfromfile.
https://www.ptc.com/en/support/article/CS30168
If you create type and attribute configuration you can export it and then use it for import many times you want.
It exports also all constraint settings.
PetrH
Yes, this is very doable.
I’ve added legal list constraints using a Java utility that I wrote.
Inputs are the Type, the attribute (that the constraint is applied to) , the list of values to be in the legal list.
Works by reading a text file with the appropriate inputs too, which I use for bulk loading.
Works well.
I have not tried to do an export but I would think that’s easier to write a utility to do that than to create a constraint.
Hi @MV_10441462
PetrH
@HelesicPetr Thank you. Yes, just found that the export can be done using TypeDefinitionExporter and import can be done using TypeDefinitionLoader both programatically and LoadFromFile utility.
