Hi @DA_10865230
Thank you for your question.
Best regards,
Any reason you have not attached your IE task that includes the Query-Tree webject to your post?
Might help in getting a response.
PTC support has this weird way of driving you through a case creation just to send you to this dead-end where you can only create a community post.
The first intent was to get ahold of a PTC support operator, that's why it's just a request, not the full thing.
Anyway, the query tree is rather basic and you can find it from the official PTC docs without the confidential matters mine has.
Here's the gist of what i have as a basis :
<ie:webject name="Search-Objects" type="OBJ">
<ie:param name="INSTANCE" data="$(properties[]wt.federation.ie.VMName[])"/>
<ie:param name="AUTHORIZATION" data="$(@SERVER[]AUTHORIZATION[0])"/>
<ie:param name="TYPE" data="wt.part.WTPart"/>
<ie:param name="GROUP_OUT" data="out"/>
<ie:param name="WHERE" data="(number='$(@form[]itemnumber[])')"/>
<ie:param name="ATTRIBUTE" data="obid" delim=","/>
<ie:param name="ITERATION" data="LATEST"/>
</ie:webject>
<ie:webject name="Query-Tree" type="OBJ">
<ie:param name="OBJECT_REF" data="$(out[]obid[])"/>
<ie:param name="TYPE" data="wt.part.WTPartUsageLink"/>
<ie:param name="direction" data="uses" delim=","/>
<ie:param name="attribute" data="<%=attrs%>" delim=","/>
<!ie:param name="attribute" data="*" delim=","/>
<ie:param name="OUTPUT_TYPE" data="full" delim=","/>
<ie:param name="DETECT_CIRCULAR_REFERENCES" data="true"/>
<ie:param name="CIRCULAR_REFERENCE_BEHAVIOR" data="LABEL"/>
<ie:param name="depth" data="9999"/>
<ie:param name="MODE" data="nested"/>
<ie:param name="WHERE" data="state.state='REVIEWED*'"/>
<ie:param name="GROUP_OUT" data="bom"/>
</ie:webject>
<ie:webject name="Return-Groups" type="GRP">
<ie:param name="GROUP_IN" data="zip,bom" delim=","/>
</ie:webject>
I'm answering to myself - and to help other users save time
Short answer : the feature is not working in Info*Engine
Slightly longest answer : We had to develop with the help of our integrator a IE subtask that mimics the "to date" maturity filter in order to reproduce what could be done in the UI. I'm not allowed to share to result of this as it is property of my company but I will notify moderator and I'm sur PTC will fix this as fast as possible.
Regards
