Maturity Date filter in info engine
DA_10865230
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.8
I had a very productive meeting with PTC support today and I can't thank you enough for the help. This made me wonder that you could help me with this other issue : We are doing a query tree with info-engine to get a BOM structure but users told me they need to apply a maturity filter (official release on today's date) and i can't figure out how to do this. We already have a working info engine task to start from
Here are the errors that I faced
no error just inadequate bom output
Hi @DA_10865230
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
@DA_10865230
Any reason you have not attached your IE task that includes the Query-Tree webject to your post?
Might help in getting a response.
DA_10865230
(To:d_graham)
PTC support has this weird way of driving you through a case creation just to send you to this dead-end where you can only create a community post.
The first intent was to get ahold of a PTC support operator, that's why it's just a request, not the full thing.
Anyway, the query tree is rather basic and you can find it from the official PTC docs without the confidential matters mine has.
Here's the gist of what i have as a basis :
<ie:webject name="Search-Objects" type="OBJ">
<ie:param name="INSTANCE" data="$(properties[]wt.federation.ie.VMName[])"/>
<ie:param name="AUTHORIZATION" data="$(@SERVER[]AUTHORIZATION[0])"/>
<ie:param name="TYPE" data="wt.part.WTPart"/>
<ie:param name="GROUP_OUT" data="out"/>
<ie:param name="WHERE" data="(number='$(@form[]itemnumber[])')"/>
<ie:param name="ATTRIBUTE" data="obid" delim=","/>
<ie:param name="ITERATION" data="LATEST"/>
</ie:webject>
<ie:webject name="Query-Tree" type="OBJ">
<ie:param name="OBJECT_REF" data="$(out[]obid[])"/>
<ie:param name="TYPE" data="wt.part.WTPartUsageLink"/>
<ie:param name="direction" data="uses" delim=","/>
<ie:param name="attribute" data="<%=attrs%>" delim=","/>
<!ie:param name="attribute" data="*" delim=","/>
<ie:param name="OUTPUT_TYPE" data="full" delim=","/>
<ie:param name="DETECT_CIRCULAR_REFERENCES" data="true"/>
<ie:param name="CIRCULAR_REFERENCE_BEHAVIOR" data="LABEL"/>
<ie:param name="depth" data="9999"/>
<ie:param name="MODE" data="nested"/>
<ie:param name="WHERE" data="state.state='REVIEWED*'"/>
<ie:param name="GROUP_OUT" data="bom"/>
</ie:webject>
<ie:webject name="Return-Groups" type="GRP">
<ie:param name="GROUP_IN" data="zip,bom" delim=","/>
</ie:webject>
I'm answering to myself - and to help other users save time
Short answer : the feature is not working in Info*Engine
Slightly longest answer : We had to develop with the help of our integrator a IE subtask that mimics the "to date" maturity filter in order to reproduce what could be done in the UI. I'm not allowed to share to result of this as it is property of my company but I will notify moderator and I'm sur PTC will fix this as fast as possible.
Regards
