I recently ran into a problem when trying to use an attribute (attribute1) value for the number using OIR code like this:
<!-- set the number to attribute1 value plus a generated number -->
<AttrValue id="number" algorithm="com.ptc.windchill.enterprise.revisionControlled.server.impl.NumberGenerator">
<Attr id="attribute1"/>
<Arg>{GEN:wt.enterprise.SequenceGenerator:WTDOCUMENTID_seq:7:0</Arg>
</AttrValue>
The NumberGenerator algorithm concatenates the numbers together, but using the value of attribute1 seems to be a problem when using an enumeration constraint with the attribute. Even though the value of attribute1 might be a number in the UI, the internal name of the enumeration is added before the attribute value when used in the OIR. For example, the value of attribute might be 15, but <Attr id="attribute1"/> in the OIR above returns attribute1_enum_15, where attribute1_enum is the internal name of the enumeration.
This is unexpected behavior, but after much trial and error, I figured out how to strip off the internal name in the OIR using wt.rule.algorithm.Substring.
<!-- Required because the value for attribute1 returned here is the enum's internal name plus underscore plus enum's value. This substring algorithm strips off the internal name returning only the enum's value. -->
<Value algorithm="wt.rule.algorithm.Substring">
<Arg>16</Arg>
</Value>
<Arg>{GEN:wt.enterprise.SequenceGenerator:WTDOCUMENTID_seq:7:0}</Arg>
</AttrValue>
In the OIR code, 16 is the length of the internal name of the enumeration plus an underscore. Since internal names don't change, I think it's safe to use this hard-coded number of characters. This might not be the best logic to use in the OIR, but it works.
