Need Help regarding Custom workflow logic to Revise the (Affected/review Objects) after Released
Rohaan
I need help regarding logic to Change the Revision for the Change Review Objects through my custom Workflow. Is there any API to get this done so the Objects are revised once they are in Released State??
HelesicPetr
(To:Rohaan)
Hello @Rohaan
I can help you with a code to revise object.
This example shows how to revise WTDocument, but it can revise whatever you need.
revise code
	private WTDocument createNewRevision(WTDocument wtObject) throws WTException
		//com.ptc.windchill.enterprise.maturity.PromotionNoticeWorkflowHelper.revisePromotables(pn, pn.getCreator(), locale);
		try
			WTCollection revisionables = new WTArrayList();
			revisionables.add(wtObject);
			WTPrincipalReference principalRef = SessionHelper.manager.getPrincipalReference();
			WTValuedMap newVersions = VersionControlHelper.service.newVersions(revisionables);
			WTCollection newWtRevision = newVersions.wtValues();
			setIterationCreator(newWtRevision, principalRef);
			WTCollection newVersionColect = PersistenceHelper.manager.store(newWtRevision);
			if (newVersionColect.size() > 0)
				WTArrayList wtArrayList = new WTArrayList(newVersionColect);
				ObjectReference wtPreference = (ObjectReference) wtArrayList.get(0);
				wtObject = (WTDocument) wtPreference.getObject();
		} catch (WTPropertyVetoException var9)
			throw new WTException(var9);
		return wtObject;
	private static void setIterationCreator(WTCollection var0, WTPrincipalReference var1) throws WTException, WTPropertyVetoException
		if (var1 != null)
			Iterator var2 = var0.persistableIterator();
			while (var2.hasNext())
				Promotable var3 = (Promotable) var2.next();
				VersionControlHelper.assignIterationCreator(var3, var1);
				VersionControlHelper.setIterationModifier(var3, var1);
		} else if (logger.isDebugEnabled())
			logger.debug("The given principal reference is null");
PetrH
HelesicPetr
(To:Rohaan)
Hello @Rohaan
revise code
		try
		return wtObject;
		if (var1 != null)
PetrH
Rohaan
(To:HelesicPetr)
Thanks! @HelesicPetr
