1. Our Windchill version is 12 CPS 17 using PDMLink/ProjectLink etc. Our industry is Aerospace and my role is a Windchill developer
My objective here is below.
In Part Structure tab, user could select the list of child and navigate to Viewing panel --> Show --> Documents, only displays the Describe document & Reference document.
We would like to show the Secondary Described By document as well.
Adding to this, Would be great if we can segregate the actions from Viewing panel --> Show --> (Instead of Documents), add Describe Doc, Secondary Describe doc & Reference doc, so that user can choose the required type and displays doc in the structure
First the PSB is not open for custo as it is based a GWT : https://www.ptc.com/en/support/article/CS165341
But still curios what is meant by "Secondary Described By document "
Nope, It's not an attachments, It's kind of Describe link document. Just like Describe Doc/Reference Doc
Secondary Described Document is more like normal Describe Doc & Reference Document which you would have seen the table in Related Objects tab.
Hi ,
you can use alias attribute to show these secondary describe link on the same row
Create an String alias with mapping describes@wt.doc.WTDocumentDependencyLink~describedBy^wt.doc.WTDocument~number
