I'm having a issue when try to print work instructions. All formats available returns a disfigured formatting.
Is there any way to improve that format?
may be you can check here if any customization is possible http://support.ptc.com/help/windchill/wnc/r11.1_m020/whc_en/#page/Windchill_Help_Center%2FWCExplorersCust_MPMLink_PPE.html
Customizations
Description
To change the time units of an operation:
Modify the following JSP:
timeUnit in coreWorkInstruction.jsp
For example, to change from seconds to minutes, change to m.
To change the time units for the steps in an operation:
Modify the following JSPs, as required:
setupTimeUnit
processingTimeUnit LaborTimeUnit queueTimeUnit, teardownTimeUnit, waitTimeUnit, moveTimeUnit For example, to change from seconds to minutes, change to m.
To relocate a table in the work instruction:
Navigate to the end of the following JSP:
Then re-design the HTML display.
To display the processing cost of an operation in a workinstruction:
Navigate to that the following tasks:
• getOperationsAndStProceduresUnder AnOperation.xml
• sortingOperations.xml
Add the following attribute to the above tasks:
MPM_Attr_MPMOperationProcessingCost
Then create the column and display data in the following JSP:
operationDetailHeaderWorkInstruction
.jsp |
To change the font, size, or color of the titles in a workinstruction:
Modify the following CSS file and the JSPs that use the definition in the CSS file:
workInstructionStyles.css
To change the logo at the top of the work instruction, or in the operation table:
Use the following procedure:
xconfmanager -d
com.ptc.windchill.mpml.WorkInstructionLogo=<logo> -t
codebase/wt.properties
where <logo> is the full path to the logo .gif file found in the following folder:
codebase\netmarkets\jsp\mpml
The default value is: ../../images/ptcLogo_workInstructions.gif corresponding to folder codebase\netmarkets\images
To add an image extension type:
Add the extension type to the following property:
onIllustrationFileExtensionAllowed |
To rearrange, remove, or add new tables:
coreWorkInstructions.jsp
