I Added all the part structure and its associated CAD into the workspace, i able to do checkout, but not the check-in.
is there any api to do check-in the CAD Object in workspace.
Hi RaikarRaghu
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please consider adding screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Hello Catalina,
I have programmatically added objects to the workspace and checked them out. However, I am unable to check them back in using the same approach. Could you please suggest any available APIs for checking in objects in the workspace.
Please find the below image for your reference.
I have performed the checkout action using the below code.
wt.fc.ReferenceFactory referenceFactory = new wt.fc.ReferenceFactory(); String workspaceNumber = getWorkspaceNumberFromName(); EPMWorkspace workspace = (EPMWorkspace) referenceFactory.getReference(workspaceNumber).getObject();
if (!WorkInProgressHelper.isCheckedOut(epmdocument)) {
CheckoutLink chilink = WorkInProgressHelper.service.checkout(epmdocument, workspace.getFolder(), WorkspaceName); wt.epm.EPMDocument wrk = (wt.epm.EPMDocument) chilink.getWorkingCopy(); System.out.println("Document checked out successfully: " + wrk.getIdentity() +"<-->"+wrk.getNumber()); }
Hi @RaikarRaghu
If you try to check in what is your problem? you do not provide any errors . If you say it does not work, that means nothing.
Logs are the most important point for solving a troubles
PetrH
Hello Petr,
If any CAD object added to workspace, then do checkout of that CAD Object it won't allow you do check-in, in the workspace, until unless it has to open in CAD Tool and do save or do some modification in that CAD, then it will allow do check-in. from CAD tool or in the workspace.
This is my understanding correct me if i am wrong.
Raikar
Hi @RaikarRaghu
Generally you are right from a process perspective , but there is an option where you can force the check-in in a UI even though it is not modified or opened in a CAD Tool,
So the option to check-in from workspace has to exist
So please share an error log where your function failed to check-in from workspace.
Additionally>
Windchill has a mechanism to build a structure from the WTPart to CADDocument
In a compare wizard, you can chose a Workspace where the CAD is modified from the WTPart Structure by Build One/Multi-Level CAD Structure
So Check-In from workspace API exists on the server side.
Workspace SetForCheckIn
PetrH.
Hi @RaikarRaghu
btw I tried to check in a CADModel from a workspace and I haven't found any problem
EPMDocument checkedInObjects = (EPMDocument) WorkInProgressHelper.service.checkin(epmDoc, "checkInFrom WS");
PetrH
Hello PetrH,
Thank you
now its working fine no issues.
one more dought i have, i added one assembly in the workspace i do checkout and checkin, after checkin i want to remove the added things from the workpspace, how to achive this.
please refer below the image for your understanding. (after checkin i need to remove all the added things from the workspace)
Raikar
