Re: How to change Type of EPMDocument type in batch mode?
MartinStLo
As per the original post
I am struggling with the authentication to avoid the  PopUp ( https://www.ptc.com/en/support/article/CS63015)
can you share how you push the --javaargs to make it works? Are you on UNIX/Linux server because the article mention that is limited to UNIX/Linux but at the same time in the note they also mention Windows... Our OS is windows so maybe this is the reason its not working.
N-Pyn
(To:MartinStLo)
Hi Martin,
I'm running Windchill on Windows Server 2013. Here is the batch file that I made for changing types of EPMDocs:
:: Changes EPMDoc type in Windchill for files listed in the .csv
@echo OFF
:: Set the encoding to UTF-8 so special characters (Ä,Ö,Å..) work
chcp 65001
:: Ask for login info
set /p USER=Username?
set /p PASSWORD=Password?
:: Ask for the target type
set /p TARGET_TYPE=Target type?
:: Set csv file name variable
SET csvfile=%1
:: Loop through the csv and execute the SoftTypeChangeUtility for each file listed in the csv
FOR /F "USEBACKQ TOKENS=1 DELIMS=," %%a in ("%csvfile%") DO (
windchill --javaargs="-Dcom.ptc.net.auth.user=%USER% -Dcom.ptc.net.auth.password=%PASSWORD%" wt.epm.util.SoftTypeChangeUtility "%%~a" "%TARGET_TYPE%"
This uses a .csv file (comma-separated) which lists all the filenames of the objects that need to be changed.
2 REPLIES 2
N-Pyn
(To:MartinStLo)
Hi Martin,
@echo OFF
chcp 65001
SET csvfile=%1
Thanks this work perfectly!
