Re: The issue about Custom TableBuilder
MS_9630520
As per the original post.
Hi @SW_10353216  ,
I am also working on the similar requirement in the custom table builder  , i have implemented the wizards and tables , unfortunately i am not able to fetch the table data in my custom form processor to process the user selected field .
How did you handled the user provided data  from the table in your form processor
HelesicPetr
(To:MS_9630520)
Hi @MS_9630520
If your input fields are correctly configured then it has to be part of a HashMap
HashMap textsAr = nmCommandBean.getText();
HashMap comboBox1 = nmCommandBean.getComboBox();
List<NmOid> selectedObjects = nmCommandBean.getNmOidSelectedInOpener();
I usually get the value for specific row based on the selectedObject in opener
for (NmOid selectedObj : selectedObjects)
// v Text Area je key NmOid+_col_+internikeyParametru example for input filed comment
String textValue = getParameterValue(selectedObj.toString() + "_col_comment", textsAr);
function getParameterValue
public static String getParameterValue(String paramName, HashMap sourceHashMap)
	String retValue = "";
	if (sourceHashMap != null)
		Iterator itr = sourceHashMap.keySet().iterator();
		while (itr.hasNext())
			String key = (String) itr.next();
			if (key != null && key.contains(paramName))
				final Object objGet = sourceHashMap.get(key);
				if (objGet instanceof ArrayList)
					ArrayList aList = (ArrayList) sourceHashMap.get(key);
					if (aList != null && aList.size() > 0)
						retValue = (String) aList.get(0);
						break;
				} else if (objGet instanceof String)
					retValue = (String) objGet;
					break;
	return retValue;
if you do not get any data by getText or getcombobox, or others functions then your input fields are not properly configured
PetrH
Hi @HelesicPetr
Thanks for your support .
Hi @MS_9630520,
Anurag
