RemothdMehtodServer
안영규
2-Explorer
RemothdMehtodServer
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M010
Windchill 9.0 에서 Windchill 11.0으로 업그레이드 이후 발생
다른 시스템에서 Windchill을 원격 접속해서 사용 하고 있음
RemothdMehtodServer.getInstance(url)
wt.properties
wt.auth.handlers=wt.auth.NullAuthentication wt.httpgw.HTTPAuthentication
Windchill 11 Upgrad 이후 타 시스템 최초 원격 호출 시 인증창이 뜨고, 최초 한번 인증을 해줘야 함
인증없이 바로 사용가능한 방법 문의 드립니다.
Hi @안영규
Thank you for your question.
It appears that your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
Some things are getting lost in translation. Can you provide screen shots to illustrate your issue?
