Version: Windchill 12.0
Use Case: Custom Windchill Report download simply the template but no data inside
Description:
I am trying to modify a custom report. However the Custom Windchill Report downloads simply the template but no data inside on my local Windchill ( hosted on VMWare). Tried adding Sys out statement and getting data on method server logs but still nothing inside the download files.
Tried Exporting Importable spreadsheet report and it has data. So probably an issue with custom one but not able to catch it.
Any clues folks
When you say Custom Windchill Report, what do you mean exactly? Can you share a screenshot?
Are you referrring to the Reports Management page of the the Utilities section? You should be able to download reports as QML or Zip. When you say data, you mean the output of the report? For that, you need to generate the report.
