Script to create a Change Request is no longer working for me...
RFS
I have some script that has been working for months...
String varName = <some text>;
String varDesc = <some text>;
<some code>
wt.change2.WTChangeRequest2 cr = wt.change2.WTChangeRequest2.newWTChangeRequest2();
cr.setName(varName);
cr.setDescription(varDesc);
<more code>
cr = (wt.change2.WTChangeRequest2) wt.fc.PersistenceHelper.manager.save(cr);
The result was a new Change Request with my preset field values for my business case.  As of today, this code fails on the cr.setDescription() call with the following message:
Message: Resource bundle/Message key = wt.introspection.introspectionResource/21
I haven't found any reason or solution yet... but I am assuming someone has.  Anyone have some ideas?
Hi @BjoernRueegg
In Windchill 12.0.0.0 is still possible to use setDescription(String)
WTIntrospectionException exception is thrown if the string is longer then 4000 characters
and the error message 21 is:
It seams that string is null
PetrH
4 REPLIES 4
BjoernRueegg
(To:RFS)
Between 11.1 and 12.0 (I belief) the description field changed from a normal text field to a WYSIWYG field. Perhaps you can't set the description field anymore with setDescription(String string) rather than using the function setLongDescription(HTMLText htmlText)?
Hi @BjoernRueegg
PetrH
RFS
(To:HelesicPetr)
It wasn't null, but it was empty and that caused it.  Thanks for the message details.
HelesicPetr
(To:RFS)
Hi @RFS
Ok Null is not allowed and also empty string is not allowed.
Good to know 😄
PetrH
