I've seen the Knowledge Hub on Security Labels and this page which allude to how to display the label on a details page.
That may have worked from 9.1 but I think things have long since changed since then. Tables and Security Label history is covered as well as watermarks. Looks great. How then can they be added to Details page?
BAE showed a data utility customization back in 2015:
Has anything been improved in newer versions (11 or 12)?
Please use this article : https://www.ptc.com/en/support/article/cs46392
The security label is added using an alias in the layout from Type and Attribute Management.
Amazing, did not find this when searching knowledge base or from Hub. Thank you.
