Security Labels Configuration
TDT
When Registering Sceurity Labels, What is the use of registering the security label in logicalform and external form in logicalattributessite.xml
<Class name="wt.access.SecurityLabeled">
<Property>
<LogicalForm>ALL_SECURITY_LABELS</LogicalForm>
<ExternalForm>SCA|ALL_SECURITY_LABELS</ExternalForm>
</Property>
</Class>
3 REPLIES 3
avillanueva
23-Emerald I
(To:TDT)
This is how the security label add in was implemented. Its looking for attribute definitions in this file.
https://support.ptc.com/help/windchill/r13.1.1.0/en/index.html#page/Windchill_Help_Center/customization/WCCG_Oview_ManageCust_BestPractices_ManagingLogicalAttributesFiles.html
https://support.ptc.com/help/windchill/r13.1.1.0/en/index.html#page/Windchill_Help_Center/securitylabelconfig/SecurityLabelConfigLogicalAttrEdit.html
This is where you declare the different types of labels you want. I believe this file has more uses outside of Security Labels to your point but this is how they chose to add in security label functionality.
Hi @avillanueva,
Thanks for the Info.
Any reason why security label should be a SCA?
avillanueva
23-Emerald I
(To:TDT)
I believe SCA relates to Server Calculated Attribute
https://www.ptc.com/en/support/article/CS369762?source=search
https://www.ptc.com/en/support/article/CS369766?source=search
I do not pretent to know why it has to be this way.
