Set Revision API is failing to set same Revision for Manufacturing View Part and Design part.
  • May 15, 2024
  • 3 replies
  • 2368 views
Hello Experts,
Set Revision API is failing to set the Manufacturing View Part as the same Revision as the Design part.
Use Case:
The Design part has A and B versions. On Design Part B Created a New Manufacturing Part then the Manufacturing Part created with Versions A. So we have to set the Manufacturing View Part Revision B to match with Design Part.
Below is the API :
VersionControlHelper.service.changeRevision ();
Failing with error: Version already exists, cannot create a duplicate: Part.  seems I'm attempting to change the revision ID to a value that already exists or is currently in use. Unfortunately, we cannot modify the revision ID to a value that is already being utilized.
How can I identify or  what would the best steps to identified the actual issue behind this?
Yogesh
Best answer by RandyJones
@Yognalawade wrote:
Hello Experts,
Use Case:
Below is the API :
According to article https://www.ptc.com/en/support/article/CS162604 that Tony referenced this is one of those:
"Works to product specification:
Seeing as how you are an actual PTC employee then you need to get R&D to actually fix the issue instead of bailing out with a "Works to Product Specification".
I have been successfully using VersionControlHelper.service.changeRevision() for years to correct revision labels. We have only used Design view. However are starting to look at using other views. Unlike Tony I just recently converted so down stream views have the same versioning scheme as the Design View. After that I have created a few new view versions and then tried using the VersionControlHelper.service.changeRevision() to set the revision of the Manufacturing view to be same as the Design View and had the same issue you are having:
"Version already exists, cannot create a duplicate: Part"
I have fixed this issue on my end by copying the relevant parts of VersionControlHelper.service.changeRevision() into my existing custom change revision class and modifying it to account for views. It is a simple change to the  getControlBranchesOf() method to add SearchConditions to limit the controlbranches to the same viewId.
avillanueva
23-Emerald I
May 15, 2024
I am still running the old method where Design view is A and Mfg view would become A.- (double revision letter), B would become B.-. Someday I will convert...but saw this problem as a headache that you are seeing.
Are you sending the changeRevision method the Mfg View part?
Take a look at this:
https://www.ptc.com/en/support/article/CS162604?source=search
I am using this method all the time but not for Mfg views. Never tried if for that. Perhaps they are blocking its use.
HelesicPetr
Hi @Yognalawade
@avillanueva has found good hint. The article mentions "The API should not be used on a regular basis".
Perhaps the method is written to use only for new objects, not for the regular changing.
So in your case there is some control mechanism in the method that do not allow you to change the revision if the object already has one.
Does not matter if it is possible now that Design and Mfg view can use same revision now. The method is not written for it as you would expect.
You need to find an another way how to change the revision.
Please provide full error and also Windchill version. If you open the generic method you would find a function that change the revision without control or you could write own based on the existing one.
PetrH
20-Turquoise
May 16, 2024
@Yognalawade wrote:
Hello Experts,
Use Case:
Below is the API :
HelesicPetr
Hi @RandyJones
I would do same if I needed it,
PetrH
olivierlp
Community Manager
June 3, 2024
Hi @Yognalawade
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Olivier
Hello Olivier,
Yes. I got the hint now.
Thanks you.
Yogesh
