Set Revision API is failing to set same Revision for Manufacturing View Part and Design part.
lnoviello-2
2-Explorer
As per the original post
Hi Randy,
can you explain me how you modified the  getControlBranchesOf() method to add SearchConditions to limit the controlbranches to the same viewId?
Your support can be very helpful for me.
Thanks in advance
Luigi
@lnoviello-2 wrote:
Hi Randy,
Thanks in advance
Luigi
	 * Modified over PTC's ootb to search for Control Branches with the same view id
	 * as the object we are changing the revision on.
	 * @param paramVersioned
	 * @return
	 * @throws WTException
	 * @throws VersionControlException
	private static QueryResult getControlBranchesOf(Versioned paramVersioned) throws WTException, VersionControlException {
		QuerySpec querySpec = new QuerySpec(ControlBranch.class);
		querySpec.appendWhere((WhereExpression) VersionControlHelper.getSearchCondition(ControlBranch.class, paramVersioned.getMaster()), ARRAY_OF_ZERO);
		// This if statement is added to the ootb PTC code.
		if (paramVersioned instanceof ViewManageable) {
			ViewManageable viewManaged = (ViewManageable) paramVersioned;
			if (ViewHelper.getView(viewManaged) != null) {
				// we have a view so add condition to search for same view
				SearchCondition sameView = new SearchCondition(ControlBranch.class, "viewId", SearchCondition.EQUAL, ViewHelper.getView(viewManaged).getPersistInfo().getObjectIdentifier().getId());
				querySpec.appendAnd();
				querySpec.appendWhere(sameView, ARRAY_OF_ZERO);
		return PersistenceServerHelper.manager.query(querySpec);
Hi @lnoviello-2,
Anurag
