I tried set default value of properties Change Management/Collector/Affected Object Collector/ Include dependent CAD/Dynamic Documents but it is not working. I created a loader file:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE NmLoader SYSTEM "standardX26.dtd">
<NmLoader>
<csvPreferenceInstance handler="wt.preference.LoadPreference.createPreferenceInstance">
<csvname>IncludeDependentsOptionForOpenCollector</csvname>
<csvcontainerClass>SITE</csvcontainerClass>
<csvcontainerName></csvcontainerName>
<csvorganization></csvorganization>
<csvparentContainerPath></csvparentContainerPath>
<csvuser></csvuser>
<csvclientName>WINDCHILL</csvclientName>
<csvvalue>None</csvvalue>
<csvlock>false</csvlock>
<csvlockOnly></csvlockOnly>
</csvPreferenceInstance>
</NmLoader>
in method server is information that all object were imported successfully but when I open Preference Manager this properties stil have got value All not None which i tried set. Anyone have got idea why it doesn't work??
Never mind, I saw that my csvname was wrong. Should be: <csvname>COLLECT_ITEMS_FROM_CHANGE_ITEM_AFFECTED_ITEMS_COLLECTOR_CATEGORY.CollectItemsFromChangeItem_AffectedItems.CADDOC_DEPENDENTS.default.option.id</csvname>
