HelesicPetr
Jan 5, 2024 2:11 PM UTC
Structure GWT Customization Wizard opener Refresh
Hello gurus,
I can not find a solution for specific GWT table refresh after the Wizard is completed.
The FormResult is defined in my own Processor that works perfectly.
I attached video where the refresh is not done and I'm looking for a solution how to do so same as check-in operation does.
I need to refresh the gwt table but I can not find solution.
I use following article but it does not work as I expect.
FormResult.setNextAction() - CS122493
//(FormResult)
result.createAndAddDynamicRefreshInfo(latestWTP, oldWTP, NmCommandBean.DYNAMIC_UPD);
 FormResult.setNextAction() also does not work as I would like or I didn't find correct javascript function to do so.
Any suggestion?
PetrH
HelesicPetr
Jan 10, 2024 2:54 PM UTC
Hi @avillanueva
I've solved it
The point is in the custom.actions.xml definition.
Normally if you follow some documentation there is an action command
<command class="com.ptc.cat.ui.client.action.LaunchCustomURLAction" method="execute"
this command does not refresh the GWT table, but
if you use standard LaunchURLAction without Custom, then the GWT table is refreshed as I need.
<command class="com.ptc.cat.ui.client.action.LaunchURLAction" method="execute"
hooray 😄
PetrH
avillanueva
23-Emerald II
Jan 5, 2024 2:29 PM UTC
Aside from check in, are there other actions that cause a refresh properly? What is that popup window that you showed? custom? Perhaps look at what happens when a filter change is applied or a table view is changed.
HelesicPetr
Jan 5, 2024 5:06 PM UTC
Hi @avillanueva
Thank you for your suggestions.
I really tried to check functions as a gwt check-in, refreshget, and aslo replace edit wizard.
But I could not find how the table refresh is done.
if it is by javaScript or any other way.
I was able to locate what classes are used by the functions but the right refresh event I could not locate.
The point is that standard steps do not work in GWT enviroment.
I know it is very deep customization and code reverse engineering 😄
PS: sure it is the custom wizard with my own custom processor 😄
PetrH
