What needs to be done so that the Affected objects are refreshed automatically.
Hi @AP_10483126
Windchill does not update the revision in the affected object automatically, only iterations are.
You need to do so manually
There is an Idea to implement button or function that allow users to update the outofdate object to the latest revision
PS> sure you can achieve your needs by customization.
PetrH
The resulting object revisions that are released by a change notice will become the affected object revision on other open change notices that have the same affected objects. In addition, BOM changes that are released by the change notice are synchronized with other open redlines that are planning concurrent changes. The Object Release States mapping rule must be defined to trigger this synchronization.
Found this above solution and it worked once set.
