Table "Action Column" takes ~20 seconds to load
tspain
8-Gravel
Version: Windchill 12.0
Use Case: Configure Table "Action Column"
Description:
Hello PTC Community,
I have a table that returns a list of WTUsers.  I have used CS169977 to configure an "action column".  The action for now is just a print statement to the MS log to confirm it is working.  If I right click a row in the table, it takes ~20 seconds for the action to load.  Once loaded, if I try again, the action loads immediately.  Any ideas on why it might take 20 seconds for the first load?
Hi @tspain,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
