Version: Windchill 13.0
Description:
We have customized a PRE_WORKSPACE_CHECKIN listener to process an attachment file and populate attributes on the associated CAD document during the check-in process. It works great, but sometimes users forget to add the attachment, which results in none of the necessary attributes being populated. Is there a way to throw a warning (or error that can then be bypassed) to the user during check-in to tell them they are missing the attachment? Ideally I would like to call this in the custom listener.
public void notifyVetoableEvent(Object event) throws Exception{
if(!(event instanceof KeyedEvent)) {
return;
//Object target = ((KeyedEvent) event).getEventTarget();
Object type = ((KeyedEvent) event).getEventType();
if(type.equals(EPMWorkspaceManagerEvent.PRE_WORKSPACE_CHECKIN))
EPMWorkspaceManagerEvent wsEvent = (EPMWorkspaceManagerEvent) event;
WTSet workingCopies = ((WTKeyedMap) ((EPMWorkspaceManagerEvent) event).getWIPMap()).wtKeySet();
WTCollection epmDocs = workingCopies.subCollection(EPMDocument.class);
Iterator docItr = epmDocs.persistableIterator(EPMDocument.class, true);
while (docItr.hasNext()) {
EPMDocument epmDoc = (EPMDocument) docItr.next();
wt.fc.Persistable pers = (wt.fc.Persistable) epmDoc;
com.ptc.core.meta.common.TypeIdentifier tiObj = wt.type.ClientTypedUtility.getTypeIdentifier(pers);
String objType = tiObj.toString();
if( objType.endsWith("VOCCADDocument")) {
QCheckHelper qChecker = new QCheckHelper(epmDoc);
// WARNING THROW SHOULD HAPPEN HERE, PSUEDO CODE INCLUDED FOR REFERENCE
if (qChecker.hasQCFile() == false) {
new FeedBackMessage("Missing QC File! Continue check-in without adding?");
// IF USER CLICKS "PROCEED" BELOW CODE EXECUTES AND POPULATES WITH BLANK VALUES
// IF USER CLICKS "CANCEL" THE CHECK-IN IS ABORTED
// END OF PSUEDO CODE, REMAINING CODE WORKS AS EXPECTED
Map<String, String> attr_value_map = new HashMap<String, String>(7);
attr_value_map.put("QC_ACTACTION", qChecker.getActAction());
attr_value_map.put("QC_ASSESSMENT", qChecker.getAssessment());
attr_value_map.put("QC_CHECK_DATE", qChecker.getCheckDate());
attr_value_map.put("QC_CHECK_TIME", qChecker.getCheckTime());
attr_value_map.put("QC_CHECK_USER", qChecker.getCheckUser());
attr_value_map.put("QC_PROFILE_NAME", qChecker.getProfileName());
WTKeyedMap keyed_map = new WTKeyedHashMap(1);
keyed_map.put(epmDoc, attr_value_map);
EPMWorkspaceHelper.manager.setAttributes(wsEvent.getWorkspace() , keyed_map);
As I wrote, it it more complicated.
here is an example how to create message with options for the error message
ArrayList<String> incorrectMessages = new ArrayList<>();
incorrectMessages.add("Delete WTP case ProcessPlan error!");
WTPDeleteMessage errorTitle = new WTPDeleteMessage("!!!! WARNING !!!!: ", "35", new Object[]{incorrectMessages});
ConflictType cType = WTPDeleteConflictType.DELETE_WTP_NOT_ALLOWED;
ResolutionType rType = ResolutionType.RETRY;
ResolutionType sType = ResolutionType.SKIP;
ConflictElement conflictElement = new ConflictElement(cType, new ResolutionType[]{sType, rType}, sType, errorTitle, wtp);
ConflictException conflict = new ConflictException(new ConflictElement[]{conflictElement});
ResolutionType resolutionList = ConflictServerHelper.getResolution(wtp, cType); // VERY IMPORTANT API TO GET RESOLUTION OPTIONS
if (resolutionList == null)
throw conflict;
} else
String option = resolutionList.getDisplay(Locale.US);
if (option.equals("Retry"))
logger.info(String.format("WTPart linked to Process Plan is deleted. WTPart: %s, Process Plan: %s User %s", wtp.getNumber(), plan.getNumber(), user.getName()));
} else
throw conflict;
API to override conflict on EPMWorkspaceHelper.manager.checkout
You have to create own conflict type
In my example I used own class WTPDeleteConflictType
How to create RbInfo file
How to create a drop down list in a workflow instance task detail page of Windchill PDMLink
Also I created own WTPDeleteMessage based on WTMessage.class
Hope this can help you.
PetrH
Related to your other linked message, I did this on a rename listener by throwing a WTException
throw new WTException("Rename for Part " + master.getNumber() + " rejected since name length exceeds 40 characters for SAP");
though WTException is a hard no bypass way which might not work in your situation.
Thanks for the response, but you are correct that this would produce a hard error with no bypass which is undesirable in my situation. This is what I plan to use as a last resort. I was hoping to find a solution using either the conflict manager (ConflictElement/Resolution API) or FeedbackMessage, but I'm not very familiar with either.
throw conflict;
} else
} else
throw conflict;
PetrH
Thank you for the response with an example! I will give this a try.
Hello @marshall_brock,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
I think we can use FormProcessingStatus.NON_FATAL_ERROR. This gives warning and proceeds with rest of the tasks.
Previously I had the same requirement and achieved the result with this.
Do you have any examples of how you achieved this?
