Trace Code Value set to non-editable
Alex1988
Is it possible to make the value in the Trace Code Column of a structure non-editable?
Hi @Alex1988,
Yes. You can do it.
From Type & Attribute Manager select Part Usage > Select Trace Code attribute in Attributes Tab > On right side, select Visibility.
And for Edit select Read Only. Refer below screen capture.
I hope this helps you.
Shirish
3 REPLIES 3
Hi @Alex1988,
Yes. You can do it.
Shirish
WCD
(To:ShirishMorkhade)
Hi @ShirishMorkhade,
Glad to know that this is possible with OOTB setting. I was suggested to write a code for for similar stuff.
After reading this post, I am able to achieve my use case with OOTB setting.
Thanks a ton Smiley Very Happy you rocks... best of luck!
Thank you again.
Hi Shirish,
At first it didn't work for me and I was thinking its because of Windchill 10.2. After retrying several times I could also set it to Read Only.
Alex
