Trigger Change Notice from Change Activity Workflow
Sha11
I have a requirement where I need to go to Change Notice workflow from the Change Activity workflow when it is at a certain point. When a particular robot is executed in the change notice workflow, the flow should again go back to the Change Activity workflow. Is there any other way to achieve the above scenario without using the Sync robot ?.
Sha
Hello ,
It would be possible through customization to trigger the other workflow on certain condition.
Ajit
zsternal-2
(To:Sha11)
Hi Sha,
Is there a reason you are trying to avoid using a sync robot? That is the OOTB approach to implementing this functionality.
