Hi All,
I have created two custom global attributes of type String on Disposition Record and assigned default value
Disposition assignee and Disposition reviewer
But I'm not able to see in UI on Disposition Record Attribute Layout
Hi @RS_10128209
Do you see the default value on the detail page?
If not, the default value is not saved in database.
If you set the default value in the type and attribute management, it does not change the existing objects where the value is empty...
PetrH
Thanks @HelesicPetr for reply.
I set default value and I have created new object still its not visible to me
Hi @RS_10128209
The default value is usually populated to the attribute in the creation wizard.
Is the attribute shown in your creation wizard?
PetrH
No the attribute is not visible in creation wizard
So it would be a reason why the value is not shown.
Add the attribute to the creation wizard
PetrH
