Use AEM to create PDF content for WTDocument subtype
PG_10960490
We've been using AEM to generate the cover page of WTDocuments for Windchill 12.0_2_7, as per typical usage.
While trying to keep the customization at a minimum, we're trying to modify the configuration files (xconf, java, and tpl) to create the Primary Content for a newly created WTDocument custom subtype. I have two questions on the subject:
1. I see in the template.properties.xconf that it is possible to define that generators and templates are used based on the document type (for example com.ptc.coversheet.DOCX.template), but is it possible to define a "hook" based on the document type?
2. Will the cover page algorithm even trigger if the new WTDocument has no content when created?
Let me know if there's anything I can clarify!
0 REPLIES 0
