Hi All,
can we know if there is any code or API to know certain version of object is published or not ? Or can we know if there is an API to know if the object is published or not so that we can then publish it ?
Just wanted to clarify if you're talking about creating visualizations, or publishing using ESI.
Assuming you mean visualizations - yes, there is some API. I have a method I created a while ago that runs in a workflow expression robot. It calls the custom package/method.
The method returns true/false. If it returns false, the method submits a publish job and the workflow routes to a timer robot. If it returns true, then it continues. There is also a custom logger in the example. It isn't necessary.
public static boolean representationCheck (WTChangeOrder2 co, boolean publish, int count) throws WTException {
//checks to see if all of the Resulting objects are published. if they aren't published, it will submit publish jobs for them.
boolean result = true;
LOGGER.debug("WF Util: representationCheck: Calling ext.site.WorkflowUtils.representationCheck(), time #" + count + ", ECO# " + co.getNumber() + ", with publish mode = " + publish);
try{
// Get a list of the Resulting Objects of the Change Notice
QueryResult qr = wt.change2.ChangeHelper2.service.getChangeablesAfter(co);
// Loop through the Resulting Objects.
while (qr.hasMoreElements()) {
WTObject obj = (WTObject)qr.nextElement();
// If the WTObject is an EPMDocument, check to see if it has a representation.
if (obj instanceof EPMDocument) {
EPMDocument epmDoc = (EPMDocument)obj;
Representation rep = PublishUtils.getRepresentation((Representable) epmDoc);
LOGGER.debug(" \"" + epmDoc.getIdentity() + "\" representation: " + rep);
// If there is no representation for the EPMDocument, then submit a publish job for one.
if (rep == null) {
result = false;
if (publish) {
String objRef = ObjectReference.newObjectReference(epmDoc).toString();
Publisher pub = new Publisher();
PublisherAction publisherAction = new PublisherAction();
publisherAction.addAction(PublisherAction.QUEUEPRIORITY, "H");
result = pub.doPublish(false, true, objRef, (EPMAsStoredConfigSpec)null, (EPMAsStoredConfigSpec)null, true, null, null, Publisher.EPM, publisherAction.toString(), 0);
LOGGER.debug("WF Util: representationCheck: Publish Job submitted for \"" + epmDoc.getIdentity() + "\"");
LOGGER.debug("WF Util: representationCheck: Done with ext.site.WorkflowUtils.representationCheck(). All Resulting EPMDocs published? " + result);
return result;
}catch (Exception e) {
e.printStackTrace();
LOGGER.error("WF Util: representationCheck error checking representations, please see MS logs for stack trace");
return true;
try{
if (rep == null) {
result = false;
if (publish) {
return result;
return true;
Hi Ben
Thanks for the input. This helps a lot. But then can you please confirm what if the publishing fails ?
Will it get republished again ? If yes is there any count or limit on sending to publishing again
The method returns a boolean. So you can call the method in an Execute Expression robot or Conditional in the workflow. Based on the result, you can route to a 5-min timer (if the result was false) or continue forward (if the result was true).
HI Ben / Graham
Thanks for the help
It worked
Not sure if this got resolved but the way I handled this is to run code that gets the QueueEntry of the publishing job.
From there, every 30 seconds (can be whatever but 30 seconds seems to work well) I get the status. If status is COMPLETED, NONEVENTFAILED or SEVERE I know the entry has finished.
Once finished I get the publishing job status. If it JOB SUCCESSFUL all is good. If it's not there's a problem and from there you can do whatever you want. Republish, send notification to user, whatever.
This seems to be a bombproof way of determining if the Representable was published successfully.
David
David
