How to modify the bellow example such that the custom function returns a collection of custom complexType records as JSON instead of only a single record?
rest/custom/domain/ToastsDomain.json
"name": "ToastsDomain",
"id": "ToastsDomain",
"description": "ToastsDomain Domain",
"nameSpace": "CUSTOM.ToastsDomain",
"containerName": "Windchill",
"defaultVersion": "1"
rest/custom/domain/ToastsDomain/v1/complexType/Toast.json
"name": "Toast",
"collectionName": "Toasts",
"description": "No description.",
"attributes": [
"name": "key",
"type": "String"
"name": "value",
"type": "String"
rest/custom/domain/ToastsDomain/v1/import.json
"imports": [
{"name": "PTC", "version": "3"}
"includeImportedEntitySets":false,
"usePropertyPaths":true,
"functions": [
"name": "GetToasts",
"importName": "GetToasts",
"includeInServiceDocument": false,
"parameters": [
"name": "input",
"type": "String",
"isNullable": false
"returnType": {
"type": "CUSTOM.ToastsDomain.Toast",
"isCollection": false
function function_GetToasts(data, params) {
var input = params.get('input').getValue();
var ComplexValue = Java.type('org.apache.olingo.commons.api.data.ComplexValue');
var complexValue = new ComplexValue();
var Property = Java.type('org.apache.olingo.commons.api.data.Property');
var ValueType = Java.type('org.apache.olingo.commons.api.data.ValueType');
complexValue.getValue().add(new Property("String", "key", ValueType.PRIMITIVE, 'msg'));
complexValue.getValue().add(new Property("String", "value", ValueType.PRIMITIVE, input));
var EntityAttribute = Java.type('com.ptc.odata.core.entity.property.EntityAttribute');
var PropertyValueType = Java.type('com.ptc.odata.core.entity.property.PropertyValueType');
var entity = new EntityAttribute(null, 'Toast', PropertyValueType.COMPLEX, complexValue);
return entity;
current output of GET http://<windchill_url>/Windchill/servlet/odata/v1/ToastsDomain/GetToasts(input='hello')
"@odata.context": "http://<windchill_url>/Windchill/servlet/odata/v1/ToastsDomain/$metadata#CUSTOM.ToastsDomain.Toast",
"@PTC.AppliedContainerContext.LocalTimeZone": "Europe/London",
"key": "msg",
"value": "hello"
desired output example
"records": [
"key": "msg",
"value": "hello"
"key": "msg2",
"value": "world"
Bellow is the solution that outputs just a couple of records.
"name": "Toast",
"attributes": [
"name": "key",
"type": "String"
"name": "value",
"type": "String"
"imports": [
"functions": [
"parameters": [
"name": "input",
"type": "String",
"isNullable": false
"name": "input2",
"type": "String",
"isNullable": false
"returnType": {
"isCollection": true
var input2 = params.get('input2').getValue();
var List = Java.type('java.util.ArrayList');
var list = new List();
complexValue.getValue().add(new Property("Edm.String", "key", ValueType.PRIMITIVE, 'msg'));
complexValue.getValue().add(new Property("Edm.String", "value", ValueType.PRIMITIVE, input));
list.add(complexValue);
complexValue2 = new ComplexValue();
complexValue2.getValue().add(new Property("Edm.String", "key", ValueType.PRIMITIVE, 'msg2'));
complexValue2.getValue().add(new Property("Edm.String", "value", ValueType.PRIMITIVE, input2));
list.add(complexValue2);
var entities = new EntityAttribute(null, 'Toasts', PropertyValueType.COLLECTION_COMPLEX, list);
return entities;
current output of GET http://<windchill_url>>/Windchill/servlet/odata/v1/ToastsDomain/GetToasts(input='hello',input2='world')
"@odata.context": "http://<windchill_url>/Windchill/servlet/odata/v1/ToastsDomain/$metadata#Collection(CUSTOM.ToastsDomain.Toast)",
"value": [
"key": "msg",
"value": "hello"
"key": "msg2",
"value": "world"
"name": "Toast",
"attributes": [
"name": "key",
"type": "String"
"name": "value",
"type": "String"
"imports": [
"functions": [
"parameters": [
"name": "input",
"type": "String",
"isNullable": false
"name": "input2",
"type": "String",
"isNullable": false
"returnType": {
return entities;
"value": [
"key": "msg",
"value": "hello"
"key": "msg2",
"value": "world"
