Workflow assignments for REWORK_ASSINGEE
dbailey-2
7-Bedrock
Dear All
Looking for some advice on Workflow expressions, I am attempting to customise the Workflow assignments as per the link below, I have added the REWORK_ASSINGEE to the roles, and the change team but when I run the syntax check I get the error below.
I have also added the roles of rework and reworkRole to the system and change team without success
Can you advise what I am missing.
I am on Windchill 11.2.1.4
https://support.ptc.com/help/wnc/r11.2.0.0/en/index.html#page/Windchill_Help_Center/WCCG_BusLogicCust_WorkflowAdmin_ChangeAssignments.html
Checking Syntax...
WfExpression_5148.java:62: error: ';' expected
rework role on the change team.
WfExpression_5148.java:64: error: ';' expected
rework tasks.
4 errors
Syntax check complete.
Best Regards
David
At least some of your problems are caused by formatting resulting from pasting the code:
// Assign participants from original or rework activity to the
// By doing so only those participants will get the next
rework tasks.
Here you have a multi line comment that is broken up. The bold lines need to be commented as well.
3 REPLIES 3
Hi David,
Can you share the code exactly as you have it entered in the workflow expression?
Hi Gravel
Please find below the syntax that I added is it taken from the support document verbatim
I would note that i see in the Change task type there is attributes for the following roles but not the re-assignee role
Name, Internal Name
Assignee, ROLE_ASSIGNEE
Reviewer, ROLE_REVIEWER
I have added the re-assignee role to the change team
wt.project.Role reworkRole = wt.project.Role.toRole("REWORK_ASSIGNEE");
wt.project.Role participantsRole = reworkRole;
java.util.Map<wt.project.Role, wt.fc.collections.WTSet> roleToParticipantMap;
// Try to get participants from the rework activity.
roleToParticipantMap = com.ptc.windchill.pdmlink.change.server.
impl.WorkflowProcessHelper.getActivityParticipants(
(wt.change2.VersionableChangeItem) primaryBusinessObject,
"Rework Change Notice Task");
// If the map is null then the rework activity has not executed yet.
if (roleToParticipantMap == null) {
participantsRole = wt.project.Role.toRole("ASSIGNEE");
// Try to get participants from the original activity.
roleToParticipantMap = com.ptc.windchill.pdmlink.change.server.impl.
"Complete Change Notice Task");
rework tasks.
wt.fc.collections.WTSet participants = roleToParticipantMap.
get(participantsRole);
com.ptc.windchill.pdmlink.change.server.impl.WorkflowProcessHelper.
setChangeItemParticipants(
reworkRole, participants);
rework tasks.
