change attribute value without new iteration
rvanveerdeghem
We have a soap request from our ERP software to change some attributes in windchill. Every time you change a value we get a new
iteration on that part. Is it possible to change the value of an attribute without getting a new iteration?
We want to see the stock of a part in windchill. So everytime the stock changes we want to do an update on the attribute. So that means
that the iteration would come to fast.
Thanks in advance
kind regards
See this post:
How to link WTPart to EPMDocument without checkout of WTPart
and this post:
Re: Java Code to add Windchill IBA Values to WTPart Object
Hi Randy,
Thanks for the information, but I can't find the solution for us.
This is what we do with a webject.
    <% logger.debug("-->CheckOut-Objects"); %>
    <ie:webject name="CheckOut-Objects" type="ACT">
      <ie:param name="INSTANCE" data="${session[]INSTANCE[0]}"/>
      <ie:param name="ATTRIBUTE" data="obid" delim=","/>
      <ie:param name="OBJECT_REF" data="${PART[0]obid[0]}"/>
      <ie:param name="GROUP_OUT" data="PART"/>
      <ie:param name="BLOB_COUNT" data="0"/>
    </ie:webject>
    <% logger.debug("-->Update-Objects"); %>
    <% logger.debug("-field: " + value); %>
    <ie:webject name="Update-Objects" type="ACT">
      <ie:param name="SESSION_ID" data="${session_id[]SESSION_ID[]}"/>
      <ie:param name="AUTHORIZATION" data="${@server[]authorization[0]}"/>
      <%for(int i=0;i<vAttribObjs.size();i++){%>
      <%AttributeObject aAttribObj = (AttributeObject)vAttribObjs.elementAt(i);%>
      <%logger.debug("attribute name " + aAttribObj.getAttributeName());%>
      <%logger.debug("attribute value " + aAttribObj.getAttributeValue());%>
      <%String sAttrib = aAttribObj.getAttributeName() + "='" + aAttribObj.getAttributeValue() + "'";%>
      <%logger.debug("attribute value " + sAttrib);%>
      <ie:param name="FIELD" data="<%=sAttrib%>"/>
    </ie:webject>
    <% logger.debug("-->CheckIn-Objects"); %>
    <ie:webject name="CheckIn-Objects" type="ACT">
      <ie:param name="SESSION_ID" data="${session[]SESSION_ID[0]}"/>
      <ie:param name="ATTRIBUTE" data="*"/>
    </ie:webject>
So now we do this with checkout en checkin. What do I need to change so that we don't need to checkout and get a higher iteration?
I'm very new in this webject code and infoengine.
Hi
I have use the below code for modifying the attribute values without checkout in EPMDocument
public boolean setNormalizedAttribute(Persistable obj, String attributeName, Object ibaValue) throws Exception, IBADefinitionException, NotAuthorizedException, RemoteException, WTException, WTPropertyVetoException {
boolean isUpdated=false;
try
IBAHolder ibaholder = (IBAHolder) obj;
ibaholder = IBAValueHelper.service.refreshAttributeContainer(ibaholder, null, null, null);
DefaultAttributeContainer defaultattributecontainer = (DefaultAttributeContainer) ibaholder.getAttributeContainer();
System.out.println(defaultattributecontainer.toString());
AttributeDefDefaultView addv = IBADefinitionHelper.service.getAttributeDefDefaultViewByPath(attributeName);
AbstractValueView aabstractvalueview[] = defaultattributecontainer.getAttributeValues(addv);
if (aabstractvalueview.length < 1) {
StringValueDefaultView svdobj = new StringValueDefaultView((StringDefView)addv, (String) ibaValue);
defaultattributecontainer.addAttributeValue(((AbstractValueView) (svdobj)));
else{
for (int k = 0; k < aabstractvalueview.length; k++){
((StringValueDefaultView)aabstractvalueview[k]).setValue((String) ibaValue);
defaultattributecontainer.updateAttributeValue(aabstractvalueview[k]);
StandardIBAValueService.theIBAValueDBService.updateAttributeContainer(ibaholder, null, null, null);
isUpdated=true;
catch(Exception e)
e.getMessage();
e.printStackTrace();
return isUpdated;
