com.ptc.windchill.migration.wbm.wc2wc.util.WBMException: WBMLDRSTATUS table does not exists.
dpchavan
9-Granite
Hello ,
 While extracting WTpart from windchill I am facing below error "com.ptc.windchill.migration.wbm.wc2wc.util.WBMException: WBMLDRSTATUS table does not exists. This usually happens if the staging schema was not created.'
I have check I can connect to staging database.
I have attached log file
Hello DPChavan,
Is this issue fixed?
Because I am also facing same issue when extracting data from windchill 11.0 system to windchill 11.1 stage DB.
Taniya Das
