expression robot
psuvendu
expression robot
Hi, I am new to PDMLink. can anyone let me know where the expression robot will write the output.
Thanks..
4 REPLIES 4
satre-2
(To:psuvendu)
it will be in background method server if you have configured background method sever
shreyas
doehr
(To:psuvendu)
Hi there,
Could you be a bit more specific? Do you mean the expression robot object in Workflows?
Please advise,
Daryl
asingh
(To:psuvendu)
Hi Suvendu,
Its better you write a Workflow logger class
package com.log;
import org.apache.log4j.Logger;
public class WorkFlowLog{
public static Logger logger = Logger.getLogger("com.log.WF");
Enable logger "com.log.WF" in log4jMethodServer.properties
Based on the level you enabled
Suppose TRACE, add line of code mentioned below in the expression robot in your Workflow.
if (log.isTraceEnabled()) {
  log.trace("TEST STRING");
System will create a new log file called "com.log.WF.log" under <WT_HOME>/logs
Aditya
asingh
(To:asingh)
Just wanted to add to my earlier email
if (com.log.WorkFlowLog.logger.isTraceEnabled()) {
  com.log.WorkFlowLog.logger.trace("TEST STRING");
