findContainerTeamGroups return exception
MV_10441462
Hi
Anybody using ContainerTeamHelper.service.findContainerTeamGroups() method to get groups from a container? I'm using this and getting the exception java.io.NotSerializableException.
Anybody else facing the same with Windchill 12?
I require a common method to get groups from PDMLinkProduct, Library and Project.
4 REPLIES 4
avillanueva
(To:MV_10441462)
Where are you running it from? Is this from a command line program outside of Windchill JVM?
I call the class(that contains ContainerTeamHelper.service.findContainerTeamGroups()) from Windchill Shell.
avillanueva
(To:MV_10441462)
There are some classes that cannot be executed of RMI which is the case since this is different JVMs.
What is the NotSerializableException in Java?
NotSerializableException in Java with Examples - GeeksforGeeks
In Java, a NotSerializableException exception is thrown when an instance of a class must implement the Serializable interface
There are work arounds if you need to execute it from command line but this helper only works from within Windchill JVM.
Hi @avillanueva
Can you please share the workarounds?
I get this exception when executed in client, but runs well in Remote Server.
