how do I programatically hide a tab on the Part Info page
smorrison
3-Visitor
I would like to have an attribute control the display of a custom tab on the Part info page.
So:
1) if I add a Boolean attribute called 'Is Pair'
2) if the 'Is Pair' = false  Then   the 'Pair' tab will NOT be displayed
a) After the part is checked in
b) When the Info page is navigated to
3) if the 'Is Pair' = true Then   the 'Pair' tab will be displayed
Thanks for the help
SRM
8 REPLIES 8
Hi Scott,
Is the additional tab you created is added through Customization (action model) or created using New Tab > Customize option available out of the box?
Shirish
Good question.
It will be added through Customization (action model).
Scott
Hi Scott Morrison,
To achieve this you can write your own validator which will first get IBA value from WTPart. Once you have IBA value you can then decide whether to display or hide custom tab.
Your validator code will looks something like below:
public class HideCustomTab extends  DefaultUIComponentValidator {
  /* (non-Javadoc)
  * @see com.ptc.core.ui.validation.DefaultUIComponentValidator#performFullPreValidation(com.ptc.core.ui.validation.UIValidationKey, com.ptc.core.ui.validation.UIValidationCriteria, java.util.Locale)
  @Override
  public UIValidationResultSet performFullPreValidation(UIValidationKey vkey, UIValidationCriteria vcriteria, Locale locale) throws WTException {
  return validateCustomTab(vkey, vcriteria, locale);
  /* (non-Javadoc)
  * @see com.ptc.core.ui.validation.DefaultUIComponentValidator#performLimitedPreValidation(com.ptc.core.ui.validation.UIValidationKey, com.ptc.core.ui.validation.UIValidationCriteria, java.util.Locale)
  @Override
  public UIValidationResultSet performLimitedPreValidation(UIValidationKey vkey, UIValidationCriteria vcriteria, Locale locale) throws WTException {
  public UIValidationResultSet validateCustomTab(UIValidationKey vkey, UIValidationCriteria vcriteria, Locale locale) throws WTException {
  UIValidationResultSet vrs = UIValidationResultSet.newInstance();
  UIValidationResult vr = UIValidationResult.newInstance();
  vr.setValidationKey(vkey);
  // Below API will give you the actual object.
  WTReference wref = vcriteria.getPageObject();
  Persistable PObj = wref.getObject();
  if (PObj instanceof WTPart) {
  WTPart prt = (WTPart) PObj;
  PersistableAdapter theIBAs = new PersistableAdapter(prt, null, java.util.Locale.US, new UpdateOperationIdentifier());
  theIBAs.load("EnumValue");
  java.lang.Boolean ibaObject = Boolean.parseBoolean(theIBAs.get("EnumValue").toString());
  if (ibaObject) {
  vrs.addResult(UIValidationResult.newInstance(vkey, UIValidationStatus.ENABLED));
  }else{
  vrs.addResult(UIValidationResult.newInstance(vkey, UIValidationStatus.HIDDEN));
  return vrs;
To hook this validator you can add below entry to site.xconf file and propagate changes by "xconfmanager -p" command:
<Service context="default" name="com.ptc.core.ui.validation.UIComponentValidator"
            targetFile="codebase/service.properties">
      <Option cardinality="singleton" order="0" overridable="true" requestor="null"
              selector="CustomTab4Part"
              serviceClass="ext.Validators.HideCustomTab"/>
   </Service>
Restart MS server and you're all set.
If IBA has value true, then Custom Tab will be displayed otherwise it will be hidden.
I hope this helps you!
Shirish
Shirish,
This approach and code makes sense.
I will give this a try on Monday.
Thanks for the help.
Scott
AbhinavKr
(To:ShirishMorkhade)
We have same issue. We have added the tab using configuration, not using action model. In that case how to hide the tab, we have no idea which user has created that tab. Could you please suggest something around this.
Hi @AbhinavKr ,
As an Admin (wcadmin or Administrator) user you can go to information page of this object type where the tab is added > Right click on it and say either "Delete Tab" or "Set Private"
Hope this helps.
Shirish
AbhinavKr
Hi Shirish,
We deleted tab using admin user but it is not hiding for other user.
Do you know in which table in database tabs entries inserted.We have full database access we can delete it from DB as well.  But DB table name we are not sure in which table these tabs entries go.
AbhinavKr
(To:AbhinavKr)
Resolved - ClientTab Table store the information about the custom/configurable tab. From this table we can get the user name who has created and other details.
